Some things just don't quite fit in.
258 Questions View all
Repair connector on HP charger
Hi,
The connector (USB-C) on my HP charger needs to be replaced. So I got a cable to cut it in half and solder the wires on this new cable’s wires.
The HP charger has no shielding and 3 wires : white, black and (thin) blue
I checked some pinouts for USB-C on the web and I would think the signals are the following : white is gnd ; black is vbus ; blue is cc
But then on my other cable, there’s only 2 wires.
So my questions :
Are the signals I determined corrects ?
Should I get another cable with 3 wires in ?
Edit. Charger picture
4 Comments
@esseivan what model is your charger?
by
I edited the post adding a picture of the charger. From what I found on google (searching for HU10436-15104 at the top right corner), i found the model number : 843319-002
by
@oldturkey03 Have you got any new information ? Thanks for the help
by
I did some voltage measurement and I got this :
White - Blue = 2.9V
White - Black = 0V
Black - Blue = 2.9V
And resistance between Black - Earth (from power plug) = 1Mohm
So Black may be the ground wire, but it seemed stranged that it wasn't connected to the casing of the USB C connector itself.
So White should be GND, blue VBUS and black Earth ?
I don't know also I my laptop will support if I wire this the wrong way, so I'm afraid to test this on my laptop, but I don't know what else I can try this on.
by
Add a comment
Chosen Solution
So your trying  to splice in a piece of cable that you’ll solder on both ends...one side to the existing USB-C (male) connector and the other back into the 3 wire cable going into the power brick?  For sure you’ll have to match up the number and size of each conductor.  According to some online literature, we are looking at USB-C Power Delivery (PD).  The Red wire is your VCC, the blue is CC (control) and the Black is the Gnd. The CC wire allows for signaling if the voltage needs to change for the sink (load…your laptop, in this case).
Score 1
3 Comments:
I also get the USB connector from the cable.
Then I tried soldering a 100k trimmer between gnd and cc wires to try to simulate the rd (or rp, I don't remember) resistor from the laptop but I only managed to get the charger to output 5v, I couldn't get it to output 12v, neither 15 (he is able to). So I'm not sure if there's communication going on the cc line as well. (The laptop is not charging with 5v)
by
Take a look at https://www.st.com/content/ccc/resource/... and maybe it will help?
by
Yeah, so it looks like the computer needs the cc line as well, it doesn't just uses it to connect the resistor, it may also detect the cable
by
Add a comment
Hello @esseivan I have a similar charger and have exact same issue. I am getting same 2.9v reading between black - blue and white - blue. I want to change the type c connector but unable to figure out which wire to connect with which pad. There are three cables but the connector has 4 pads (G, D+, D-, V), please help
Add a comment
I'm working on this problem with my charger as well but I chose USB-C that came with wires to solder to the chargers wire. I tried connectors with 2 wires and 4 wires and none worked On my charger the blue wire is hot and red as ground. There is also a bare uninsulated wire which is ground as well. Meter reads 4 volts with blue wire to bare wire ground. 3.4 volts with red wire to blue. It is clear that the colors don't follow the standards with regards to wire color. In my attempt to use the USB-c with 4 wires, the power/charging light does not come on. The four wires are black, white, red and green. The charger wire is red, blue and bare wire. I've tried connecting them in various combination without success. When I thought to be a simple repair to good chargers with bad connectors, it's become a problem solving issue probably not worth the trouble. However if you have a solution with what I need to replace the broken connectors, I would be greatly happy.
Add a comment
Add your answer
Nicolas Esseiva will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 72
All Time: 5,390
