Device and repair pages for the Motorola Moto G7 Power smartphone. The phone was released in March 2019, with model numbers XT1955-1, XT1955-2, XT1955-4, XT1955-5, and XT1955-7.
47 Questions View all
Why is the charging on my phone so strange?
I bought a G7 power through Verizon earlier this year and it has been great, but recently there has been an issue in which the phone does not want to charge unless the charging cable is angled in a particular way. I have to fiddle with the cable before bed every night and make sure it stays in the same position or else it stops charging.
I've tried battery calibration, swapping out cables, plugs and outlets. I also contacted Motorola support but they said I'd have to mail it in or find a repair center nearby. There were no such centers nearby and I'd rather not mail-in my phone (REALLY busy schedule coming up and I pretty much rely on my phone to stay organized)
Any workarounds or DIY options? Thanks in advance
Score 2
Add a comment
Most Helpful Answer
@biix “does not want to charge unless the charging cable is angled in a particular way” appears to be an issue with the charging port. You can either try and solder a replacement port like this one on the board or you can replace the board/flex cable with a part like this. To disassemble and work on your G7 use something like this video
Score 3
Add a comment
Try a guide on YouTube on Paul’s hardware channel. He recently showed how it was possible that a dirty charging port can cause your device not to charge or charge properly. It’s worth a look and try ;-) The other possibility is as already mentioned,those are relatively cheap and easy to replace
Score 1
Add a comment
I've been experiencing that same problem. It first originated when I plugged the g7 in overnight to charge and came back to a totally dead battery and the phone wouldn't turn on or indicate the charging cable contact visible by a white blinking light in the upper right top. I messed around and finally was able to charge it enough to reboot it by holding the down volume and power button simultaneously for a good 15 seconds and just selected restart in safe mode. After examining the situation I noticed a part of the center housing frame directly underneath the charging port was totally missing, broken off so I chalked the charging issue up to that. Ordered and replaced the port itself and used epoxy to build up the frame by shaping it after it hardened then reassembled the phone with the new charging port board section (which took me a long time to find online and not an exact replacement but after earning myself a degree in hardware purpose I purchased my best chance of choice of replacement part) . After conversing with Motorola to get an estimate for repair I was quoted a price of $165 for the repair which included the mid frame replacement but to purchase a brand new g7 was the same price as the repair so I had nothing to loose by taking on the project myself without any previous knowledge or experience with a non-removable battery and back. So here I am several months later experiencing the same issue as before and now thinking its not a hardware issue (although I'm sure its t helping matters) its not the charging port itself because I experienced the same identical issue with the OEM board and port as I did with an after market Chinese replacement board and port. It worked great at first when new and when the pert was newly replace so I'm not sure but have a difficult time believing its program issue because it either works or it doesn't when its software issue but again the only exposure to any of the phones components and technical functionality comes from troubleshooting this charging port issue. However while aggravatingly messing around I took notice yo a piece of black thin rubber that covers the very back of the inside of the port and is cut out around 4 circular contact faces and is loose at the side or vertical side looking at the port went the center mid section with the pins is at a horizontal view and when tinkered with , contact improved slightly but only for 2 or 3 times of plugging in the cord. My next thought is to replace the charging board again, purchasing an adapter (male c to female c) and permanently securing it as an unremovable appendage that extends out of the bottom of the phone or doing the same permanent connecting approach with a wireless charging dongle but either way the fast charging capabilities will most likely disappear.
Add a comment
Can anyone provide the part number for the Motorola Moto G7 Power Daughterboard. It has to be cheaper that $165
2 Comments:
I just tore downy moto g7 optimo maxx (power after purchasing a new 6180 replacement upgraded battery, a new charging port board and back cover. Due to me not having soldering experience, it has just rested here since, like 6 - 8 weeks. It has a clear and healthy IMEI idas well. If you may be interested in any pf these new parts or possibly a original part from within the phone, I will be more than interested in discussing this further and you wont find more reasonable costs. I hadn't planned on parting out the phone but for me its not going to be worth any further investment from me. Here is my email, feel free to send me any thing that may have peeked your interest.
phillipsjamey1970@yahoo.com
by
Email me I have particular info and options to offer along with some links to eBay and amazon (i think amazon) but just to much info to list here. Genuinely honest intentions and have integrity as well so no risk for you. Im leaving my email, actually 2 of my email addresses here to be absolutely straight up. It even my legal full name! You'll be glad you did and if not, a couple of minutes invested for a possible good opportunity. Ill post a few pics I just took at home right before this message and will list them in the answer area.
phillipsjamey1970@gmail.com
by
Add a comment
back cover inside
back cover outside
upgrade bigger battery brand new
Original OEM board side1
Orig OEM side2
replacement part1a
replacement part1b
replacement part2a
replacement part2b
Each board cost me under $15, the super beefy battery under $27 and the brand new still wrapped back cover under $17 but willing to help you out and considering I no longer have plans for these items. Ill factor in everything and price them reasonably and no payment until you get the items, whichever ones if any or all, and everything is completely satisfactory and then the payment as agreed upon in full or return of whatever you decide not to use. Doesn't get any better than that? And besides all that even if you're not interested I have some information to help you find a part that you need but it's not an easy part to find so I would rather talk to you personally and explain a couple of things that I've learned over the process to help you out.
Add a comment
If you rather not mess with all that above, here is the " Ebay link" of the charging port board I had located fto replace my damaged one for my Motorola G7 Optimo Maxx (Straight Talks naming for the G7 Power) US version. You will find most all of the identifying information within the displayed sellers ad for matching accuracy.
https://www.ebay.com/itm/175201206791?mk...
Add a comment
Add your answer
biix will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 938
