Toshiba laptop from 2011. This laptop came with a Celeron, Pentium, Core i3, Core i5 or Core i7 processor.
after boot computer shut off
My device isn't Toshiba,It's Local brand. after boot computer shuts off,If I press power switch It boots again,then shuts off
3 Comments
Hi @iamfixer ,
What is the make and model number of the laptop?
Does it do this with the charger connected and switched on?
What OS is installed?
by
@jayeff tmt-YA - 4A 94V E144139 OEM motherboard,OS win 10,with charger plugged in or without same thing happening
by
Add a comment
1 Answer
Chosen Solution
Hi @iamfixer ,
Try starting Win 10 in safe mode and check if you can get to the Recovery menu area without it boot looping.
If you can, go to Troubleshooting > Advanced > Start Up Repair and follow the prompts.
DO NOT select "Reset this PC" as it will erase all your data and reinstall Windows if you select the wrong option after that. Just so you are aware of this.
Score 1
Add a comment
Add your answer
Shehan Kavinda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 199
