Repair and disassembly information for Logitech's ergonomic MX Vertical wireless mouse. Released in 2018 and identified by model number M-R0074.
MX Vertical Optical Repair
Hi there, my MX Vertical isn’t moving the cursor anymore.. However, the buttons still work (e.g., left/right click, wheel, fwd/back, etc.). Does anyone know of a way to repair this?
Is the optical sensor easy to replace? Could this perhaps just come loose?
Any experience with this issue would be greatly appreciated as I haven’t seen anything pertaining to this particular mouse.
TIA
Score 2
1 Comment
Wow, thank god for the internet. This was super easy to fix once I found my super tiny electronics screwdriver. I dropped my mouse super hard and thought it was done for. So glad that this $70 mouse was salvaged from the landfill by some quick googling and helpful photos. Thank you so much!
by
Add a comment
Chosen Solution
So I figured it out. Thanks to that video provided by @justicegoat I was reassured that this device could be opened safely without breaking it, i.e., no glue.
I opened it up and noticed that the sensor was just loose and was no longer pointing to where it should be. Unfortunately the anti-stick strips couldn't be salvaged.
It was easy to clip it back in place. I had dropped this mouse from my desk enough that it must've dislodged from its clipped home. Oops.
Great mouse, though.
See images.
Score 15
8 Comments:
Thank you, thank you. Even I, a 64 year old grandma with limited tech experience, was able to fix my mouse. Thank you!
by
you save my mouse, thank you !
by
100% - -Just saved me getting a new one - was sensor that had moved after dropping it -- Thank you sir :)
by
Thanks a lot, Sir! You're a saver.
by
This worked for me too. Thanks for your help!
by
Show 3 more comments
Add a comment
Found this video, it’s in Vietnamese but it helped me open the mouse and fix that cursor issue.
turns out the lens connector was loose
Good luck!
https://www.youtube.com/watch?v=09ffN9M6...
Score 6
Add a comment
I followed @l3fl3r instructions. Thanks!
Also, by being careful, I managed to remove the anti-stick strips/skate/feet and put them back after.
Score 2
Add a comment
you can find replacement scates on aliexpress, search for ..2 Set Mouse Feet Glide Sticker Curve Edge Skates For-Logitech MX Vertical/MX Anywhere 3 Mouse M04 21 Dropshipping
Score 1
Add a comment
I don’t think you can replace the optical sensor since most mouses have it soldered on the mainboard.
1 Comment:
No, you're correct. When I contacted Logitech, to order the anti-stick pads I ruined, they only offered to replaced my mouse. So spare parts are not going to be available. But In my case, the issue was the sensor and since it was an easy fix, I can still use it. But without the pads, it's not great for anything requiring any high dpi. It'll be a donor mouse should I run into any issues with my replacement.
by
Add a comment
Thank you for the useful information.
Also, I was able to save the anti-stick strips by using a heat-gun to revove them and then to re-attatch them. I heated up the strips so that the glue turned softer and allowed me to remove the strips easily. When I was ready to re-assemble, I heated up the strips again so that the glue became sticky again and then just put them back on the mouse.
Add a comment
There is no need to replace or remove the anti-stick strips! You can simply locate the screws by sliding your nails along the strip and feeling for the holes. Once you find a hole, simply use the screwdriver to pierce through. This way, the strip remains intact ;)
Add a comment
Thanks for the solution. I could repair my MX vertical. I can confirm that by being careful is it possible to reuse the pads (I started to peel them off with a blade and then remove it very gently).
By reassembling the optical sensor, I've put a small drop of glue on the support, I hope that it will be less prone to come detached again.
Add a comment
Add your answer
David Lefler will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 47
Past 30 Days: 250
All Time: 9,999
