My touch screen not working after dropped and small crack
My kid knocked my ONN tablet off the table and cracked the screen a little and now my touch screen wont work
Patricia Lightner that crack may have ruined your digitizer. Your Onn tablet is a bit off-brand so it may be harder to find a replacement touchscreen. Let us know what model it is so we can try and help you out further.
100015685 the model number
Thanks for your help, I appreciate.
im sad because my tablet won't work
The screen IS the digitizer. It controls the touch so cracking it messes up how it reads and if it reads anything you try to enter. You can buy replacement screens on eBay and watch how-to videos on Youtube. The average cost of replacement is under $20.
My screen is not working it's not cracked and hasn't fallen
There is an adapter called USB OTG (Universal Serial Bus On The Go) that you can get online on walmart.com for a few dollars. Then, get a keyboard and mouse combo like this one: https://www.walmart.com/ip/Logitech-MK27... and as long as you don’t break the actual screen inside (like the way i did, help?) you should be good
Of course, my model number is ONA100005206 and it is the 7 inch model.
The inside screen is break
@bamas1211 only way to fix that is by replacing the complete screen
i have a onn tablet
can you give me info to take screen off
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 118
All Time: 13,797
12 Comments
Hi,
What is the model number of the tablet?
by jayeff
@jayeff
Hi,
I have the same problem with my son's tablet. His tablet is Onn, Android Version 9, and model number is 100005209. How do you repair the cracked touch screen?
Thank you!
by Maikao
HI @tear_fall12 ,
There is not much useful information online, regarding your tablet.
For example has it got a separate touchscreen or it it fused in with the LCD screen into one complete display assembly? I couldn’t find a replacement part for your model tablet online
The only way to know is to open the tablet.
Again there is no information on how to do this.
You could try searching YouTube (I found nothing there) but in the end it may come down to treating it as a generic no name tablet and trying to open it the same way.
Once open it can be seen whether it is one screen or two.
If one then perhaps searching for the part number printed on the back of the screen itself may get a result for a replacement.
This is the problem with the low end tablets, mass produced to sell at low cost with no expectation by the manufacturer of it being able to be repaired if they go faulty.
Perhaps the 2nd answer below is the best solution to your problem
by jayeff
when I put my tablet on the side of my bed it just broke
by Aniya Grady
I need to replace the whole screen the inside screen broke
by Paula Shirley
Show 7 more comments
