Monochrome laser printer introduced in 2012. The printer is rated for 35 PPM and the first page comes out in 8 seconds. Depending on which model you own (a/n/dw/dn/dne), you will have different options and available features. Uses HP 80A/80X toner cartridges.
20 Questions View all
Prints from my 10.13 High Sierra MBP, but not 10 Home 1809.
This has been an ongoing issue since 1/16 with no fix so far. The printer still works on my MBP, so I know the printer is fine - it’s either a compatibility issue HP is using to sell printers by not fixing it or something with the 1809 build - which I CANNOT downgrade as that is what MSI shipped on this laptop.
Anyway, I am using the latest drivers available for this printer from HP and running 20180318 (3/18/2018), which is the latest firmware available I flashed to fix a Tray 1 sensor error. The printer worked fine with this firmware on my old laptop, which was a factory 7 machine upgraded to 10 Pro. The drivers are not out of date and the firmware is current as it is going to get - HP has not updated them again for a while. I may still have some of the old firmware installers backed up as I kept them just in case I need to downgrade but I would need to dig through 2 external hard drives - however, I know where they are. High Sierra *does report* that the printer is offline, but it forces the job through anyway so I think that’s just a MacOS glitch.
Are there any known issues with 10 Home 1809 that are more or less crippling my ability to use the printer I may be able to fix, or is it sound like my time is up and it’s time to upgrade and knocking this down to a Mac/Linux printer? I know it isn’t my scanner (HP G4050) because it broke before I acquired it. And no, that’s not a typo - I’m lucky enough to still be on 1809.
8 Comments
Hi @nick,
Check that the print spooler service is running
Win key + R
type services.msc scroll down to print spooler and check status.
Double click entry to change if it is stopped
Just a thought.
by
@jayeff Print spooler->Running
I tried to restart it as a final ditch effort. No help.
by
Hi @nick ,
OK
On a different tack.
Is it a typo in the question that the Win OS is 1809?
If so you're a long way behind it's up to 1909 now
by
@jayeff I didn't get forced onto it so it's not. I'm holding out because of the track record M$ has had with Win10 feature updates as long as possible.
by
Show 3 more comments
Add a comment
1 Answer
Chosen Solution
Hi @nick ,
Just confirming that this is the latest drivers that you have installed? see Driver - Universal Print Driver Dec 1 2019
Also interesting that just lately when accessing HP support for laptops I noticed a pop up window appears with info that states "Fix Windows update issues print spooler......
Here's a link as an example of what I mean.
Hope the info box opens for you as well.
Cheers.
Score 2
2 Comments:
@jayeff I'm using the M401n specific driver to get the device toolbox - I have the 2 line LCD model so I can't drop it :(.
I tried the PCL6 UPD too - nothing. The drivers are current and I tried the M$ troubleshooter and neither worked. I don't see the M401n on the compatibility list, but the thing is it's similar to the dn where the only difference is the factory options.
*OLD COMMENT MIGRATED TO ANSWER*
by
Hi @nick,
Did you try installing the printer driver in compatibility mode and see if that worked?
Select an OS that you know it worked in.
Just a thought.
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 144
