A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
534 Questions View all
Won't turn on after Water Damage
Hello.
I recently received a MacBook Pro (13-inch, 2017, 2 TBT3) with water damage.
I treated all the components for water damage by cleaning with isopropyl alcohol. I also put the board in a heating oven for 1 hour on 175 degrees Celsius.
When i opened the MacBook the components didn’t look to bad to begin with. After thoroughly cleaning them they look like new.
The battery seems to be dead as i can only measure 2-3V on it. If i plug in the charger i measure about 12V on it but even after charging it overnight the battery is still at 2-3V
After all this the MacBook doesn’t show any signs of life. So i am hoping anyone out there has any more tips or tricks i can try.
Is it depended on the battery being fully functional or does the main board definitely have some issues?
Add a comment
1 Answer
I believe that even if the battery doesn’t hold charge it should power up if everything works. I believe the laptop motherboard is probably fried. You could pull the SSD off and try on other Apple computers to make sure its not storage problem.
Add a comment
Add your answer
Total Repairs AS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 57
