A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
PS4 System Install Problem
I took my ps4 to a technician because I had no video output. He changed the integrated video chip, but was unable to reintall system. I am trying to do it myself, but for some reason when asked to insert the pendrive with the system software, i am unable to press the Ok button(controller connected to usb and working). On the other hand, all options in the safe mode are disabled but option 7.
Edit: I am Adding images of the problem.
https://imgur.com/a/muivaSJ
2 Comments
use the d pad on the left hand side of the controller if not I have no clue
by
Tried both the pad and the L3 button.
by
Add a comment
Chosen Solution
After Trying everything, found out that the problem actually was the “right“ pad button in the controller. Now a new error presented ce-35888-2. I will open a new question for this. Thank You EveryOne!
Add a comment
Did you tried to format the drive before you put it back in the PS4? Otherwise try another (empty) HDD just to test.
4 Comments:
I didn’t format it. But Tried a brand new sdd, and It was the same.
by
Did you download the full software (not update only)? And the USB is FAT32 formatted right? When it should reboot the console, does your PS4 reboots or turns off? If it turns off instead of rebooting, please unplug the power cable and connect it once again, then turn it on.
by
I downloaded the full software, and formatted the pendrive to fat32. I never get to the reboot part of the process. Check images for clarification on the error. https://imgur.com/a/muivaSJ
by
Ah I get it now. When you try the controller with bluetooth it won't simply connect (keeps searching, flashing white light) ? And with USB it's not working either. And did you tried multiple controllers ? Perhaps it's even related to the USB ports on the motherboard... Did you tried other USB ports, also the backside?
by
Add a comment
Add your answer
alvarez_fernando_l will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,766
