The smaller, economical version of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
52 Questions View all
Why my phone keep vibrate when charging it with charging port?
hi
I have a question about my s10e
when I turn off the phone and charging it with charging port, it will just continuously vibrate but not charging or turn on the screen, and when I turn on the phone, it won’t charging when I using charging port, but when I charging it with wireless charge it working normally.
I try many cable or adapter, but it still happen.
is this happen due to the bad charging port or bad chip ?
thank you ~
Score 1
3 Comments
On My REVVL 6:
I went to:
Settings / Sound /
Charging Sounds and Vibration
I turned it off and vibration stopped.
Still trying to turn off flashing screen. Ughhh!
by
I tried the above to no avail. Sometimes it doesn’t do it, but it has become a very T-Mobil problem with their phones. It affects the charging since the vibrator takes extra power every time it activates. Never had this problem with other brand phones until I bought this cheap Revvel 5049 phone. T-Mobil fix your freaking phones… or fix your engineering.
by
It's doing this on Samsung android phones and they both original. S10+ and A20. It keeps blinking and vibrating when charging. It's becoming annoying and doesn't want to charge sometimes
by
Add a comment
Chosen Solution
It seems that the power adapter or USB cable is faulty. If your charging accessory isn’t working correctly, it may have difficulty connecting the phone to the power source, making it vibrate each time it reconnects.
How to fix? Check the charger or cable for external damage and make sure the connectors are clean and debris-free. Examine the charging port on the iPhone to see if it has any dust or debris in it. If it does, clean it out gently, making sure to pull dust out rather than push it in. If you have an alternative power adapter or USB cable, swap it for the original and see if that charges the iPhone without making it vibrate.
Score 4
2 Comments:
hi I try few cables or adapters, and I also clean the charging port but it still happen ~
by
It happened to me also and when I got up from bed I turned it on and I got scared and then it vibrated. But not continuously.
by
Add a comment
On my REVVL 6
Through "Settings / Sound" I found the feature "Charging Sounds and vibration"
I turned off this feature and it stopped. However, screen still flashing while charging. Grrrr!
Add a comment
Thanks! I went to settings, sound, advanced, and turned off option to vibrate and charging sounds. Yay!
Add a comment
Add your answer
Koim Tiion will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 139
Past 30 Days: 729
All Time: 35,140
