The HP Envy 14-u series includes models 14-u000 and 14-u099.
2 Questions View all
Will show charging light but will not turn on
(note I do not know if this makes a difference but I have the 17-inch version of this laptop but it did not show up)
So this one is weird, so I was using it and it died so I plugged it in the charging light on the side turned on but when I hit the power butting the charging light turned off and the laptop would not turn on. So I unplugged it and plugged it back in but the charging light would not turn back on so I let it sit for a few days plugged it in and the same thing happened but like two months later I plugged it in and it turned on then a few days ago it happened the computer died and would not turn on I have replaced the battery to see if that was the problem but it was not and I have no idea what is wrong with it. Any Ideas?
3 Comments
have you tried turning it on with out the battery ?
i do not know if it will change anything
by
Hi,
What is the full model number of the laptop?
by
I have tried to turn it in without the battery but the same exact thing happens and the full model number is 17t-s000
by
Add a comment
1 Answer
Chosen Solution
Hi,
You may have to get back to basics and check a few things first.
If you have a DMM (digital multimeter) and know how to use it, then this will help.
a) Using the DMM’s DC Voltmeter function, check that the laptop’s charger’s output is +19.5V DC. (Have you tried a different compatible charger at all and check if that works?)
b) Using the DMM’s Ohmmeter function check the laptop’s power connector cable for continuity from the laptop’s power socket to the cable’s connector plug that connects to the motherboard..
Here’s a link to the hardware maintenance manual for the laptop, taken from this webpage.
Scroll to p.49 to view the necessary pre-requisite steps and then the procedure to remove/replace the cable.
Test the cable with it disconnected from the motherboard.
If it turns out that the socket part of the power connector cable is faulty internally, (sometimes the centre pin breaks away internally from the connection, therefore there is an o/c in the path for the power to the laptop) then the entire cable will have to be replaced as it cannot be repaired.
The part number is shown on top of p.49 in the manual. If you search online using the part number only in the search term, you’ll get results for suppliers.
A faulty socket could mean that the laptop’s battery was not charging properly and therefore the laptop turned off and also that the supply from the charger was not getting through to run the laptop either.
Score 1
Add a comment
Add your answer
David Lockhart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,922
