Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
29 Questions View all
sim card is block for call, sim is not from verizon
I am using Moto Turbo 2 Droid, in start it work well, now it is blocked for SIM card giving error that, SIM card is not from Verizon but before it not giving error of SIM.
unable to start calling i setup SIM on global setting.
Add a comment
Most Helpful Answer
Verizon requires that the device be owned 60 days, then the device will be unlocked. Otherwise, other SIM cards will be rejected. Also, is the card GSM? Verizon phones are only CDMA-compatible.
Score 1
2 Comments:
60 Days owned? what that mean?
Yes the card is GSM.
by
Well, there's your problem. Verizon only uses a CDMA network, which does NOT work with GSM cards.
by
Add a comment
If your SIM card is blocked for calling, it's most likely because it's not from Verizon. In order to make calls on a Verizon network, your SIM card must be activated with Verizon. You can do this by either purchasing a SIM card from Verizon or by transferring your existing SIM card to Verizon. If you have an existing SIM card that you'd like to transfer to Verizon, please contact us and we'll be happy to assist you.
See more info https://grouphowto.com/verizon-sim-card-...
Add a comment
Add your answer
Kamran Shah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 347
