Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
Bottom Speaker Mesh Damage
I have an iPhone 8. In an effort to remove some dust and debris, I accidentally punctured one of my bottom speaker holes with a thumbtack.
I wanted to know if it worth it to replace the mesh.
I do not want to compromise any water resistance the phone may have by opening up the device.
Add a comment
Chosen Solution
As you can see in the product description, ‘Mesh covers are part of the water and dust ingress protection for the phone. ‘
iPhone 8/SE 2020 Speaker and Microphone Mesh Set
So, my answer is yes.
I understand that you do not want to compromise any water resistance the phone may have by opening up the device, but a damaged speaker mesh might also get your phone in a risk of water damage.
Replace the mesh covers for the speaker, vent, and microphone openings. Image
Product
$2.99
Score 1
1 Comment:
It doesn’t matter it doesn’t affect your phone I put it in for 5 minutes with a mesh puncture and it’s working perfect ??
by
Add a comment
Most Helpful Answer
Getting the mesh replaced requires opening up the phone which removes any water resistance when it is opened. Better to leave it as it is.
Score 2
Add a comment
Depending on which holes you poked.
If it is the right side holes, probably water resistance wasn’t compromised in the first place. You can do a pressure test to determine if the phone is still sealed.
If it is the left side holes, you’ve destroyed water resistance already and it is going to be a complex repair to replace all seals and meshes, and there will be no sure way to test after all this.
So consider water resistance permanently lost if left holes are damaged.
Score 1
1 Comment:
@tomchai When you say "right side holes" and "left side holes," do you mean speaker holes and microphone holes, respectively?
One hole is damaged. It's one of the speaker holes (if you're looking at the phone, it's on your right side). But it's the hole closest to the charging port (leftmost of the six). Does that make sense?
Do you suggest I do anything in particular?
Thanks
by
Add a comment
Add your answer
Emily will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 47
All Time: 7,139
