Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 Questions View all
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
1 Comment
I don’t know what I did different, but I got the display to work.
Thank you for the replies
by
Add a comment
Most Helpful Answer
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
Score 1
Add a comment
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
Add a comment
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
Add a comment
Add your answer
sunruh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 81
