The HP Chromebook 14-ca061dx, is a laptop made by HP with the Chromebook software, which is compatible with Google Play. It contains a 14-inch display, 4 GB of memory, and 1.1 GHz processor.
Where is the write protect screw
Anyone know where the write protect screw is?
Score 1
1 Comment
Hi Waseem Azma
Suggest you to follow the guide and teardown to the mainboard section
HP Chromebook 14-ca061dx Motherboard Replacement
Im not sure .. but if you observe on step 13.... there is a missing screw at the bottom right of it. check and compare with yours.
by
Add a comment
1 Answer
Most Helpful Answer
Young aspiring engineer - i have two images attached that will show you what your looking for. Apologies on the quality of the images I’m 55 and a little cranky. This system belongs to a friend of mine and believe his son may of got carried away with the handling of the motherboard
. Time for a little repair. Careful with adding another OS onto Chromebook, referencing Windows primarily. A linux distro would be my choice due to its light weight nature. These are just suggestions, not an expert but like to bring things back to life. ciao
Score 3
Add a comment
Add your answer
Waseem Azma will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 1,966
