A collection of guides and support to help with washer repair.
CL error code on top loading portable washing machine
I have a GE portable washing machine model number gnw128psmoww. It will power on but will not accept any input or start. The error code is CL which is not listed and there is no documented child lock, Help.
2 Comments
Hi @nicole1990 ,
Have you tried disconnecting the power from the machine for 5 minutes to check if this resets it, you didn't mention if you had or not?
by
Sorry, yes I have. No dice.
by
Add a comment
1 Answer
Most Helpful Answer
Hi @nicole1990 ,
I think that CL means Control Lock.
The Control Lock is used before or during a cycle to prevent any selections from being made.
To lock/unlock the washer controls, press and hold the Signal and Delay Wash buttons for 3 seconds.
Score 2
2 Comments:
Thank you! This is the answer. I'm now wondering why this isn't in the manual!
by
Hi @nicole1990 ,
It is in the manual that I downloaded. See p.8 ;-)
They probably don't class it as an error code. It's more an information code. Perhaps that's why it isn't listed with the error codes
by
Add a comment
Add your answer
Nicole will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,367
