The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
319 Questions View all
Why says check lint screen . What’s that?
My dryer he3 it say check lint screen
Add a comment
1 Answer
Most Helpful Answer
This is your lint screen. You must clean it after every dryer cycle.
Score 2
3 Comments:
just a follow up to the previous post, from experience if after cleaning the screen and the error is still present, there is likely a clog down inside. could possibly use a vacuum to clear or may need to disassemble and clean to clear if all else fails. also, depending on the unit you have , you may need to manually clear the code after cleaning. would want to do a google check to see if applicable for your model.
by
Here's a video on deep cleaning it if you have already been doing what Travis told you:
https://www.google.com/search?client=saf...
by
Thanks mayer. I probably should have posted that too but couldn't find the one for his dryer. That is the same screen but I have different dryer.
by
Add a comment
Add your answer
Khalil Burbar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 2,519
