Whirlpool Gold Series Dishwashers can be identified by model number WDF750SAYM0, WDF750SAYM1, or WDF750SAYM2.
22 Questions View all
Why is my display reading 1H and flashing occasionally?
I have. Whirlpool Gold Quiet Partner 3
Model # GU2400XTPQ7
Age unknown for sure
Ran a regular cycle like always last night, this evening when I come home the display is reading 1H and blinking every once and a while. When I tell it to cancel, it starts running a two minute cycle but doesn’t sound like it’s producing any water. I ran a regular cycle to try to clear it. Dishes were wet by the end, so it can produce water, but the 1H came right back after the cycle.
How doi do I fix this, or is the machine just toast?
Update (03/11/2020)
Model # GU2400XTPQ7
New update:
I did the sani-rinse/heated dry combo and it worked temporarily.
it gave me the code d3, and did a countdown from 7, flipping through different settings until it turned off. However about 7 hours later it randomly kicked on for about 1 minute with nothing on the display and just now the 1H was back on the display even though no one has touched it.
1 Comment
Hi @kallile ,
Check if there is a "tech sheet" taped behind the dishwasher's kickboard (toe panel?)
If there is it may help you to narrow down to what the problem may be.
by
Add a comment
Most Helpful Answer
Hi @kallile ,
Did you try pressing the Cancel/Drain button to clear the code?
Here’s an image taken from the user manual that describes Delay Start
(click on image to enlarge for better viewing)
Score 1
Add a comment
@kallile we really need to know what model this is. the H1 could possibly be an 1H which could make this a 1Hour delayed start. In the meantime try a reset and see if that changes anything. This should work for your machine:
  • Crack the door open by about 2 -3 inches
  • Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the control panel in quick sequence to enter diagnostic mode.
  • Close the dishwasher door and engage the door latch.
  • Wait 10 seconds before pressing the "Cancel" button to reset your dishwasher.
Add a comment
Add your answer
Jill Wines will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,279
