Microsoft's third-generation Xbox game console, released November 22, 2013.
Sync issues on Xbox One Console
Okay, I’ve just replaced a faulty hard drive in my old-style Xbox One. In doing so I had to go into factory settings by pressing the button and the eject button, so I know there is no physical problem with the button. However, now when I press the button, the Xbox will not flash to sync a controller. I’ve tried syncing the controller using a USB cable, still no joy. There are no issues with the controllers, I have two Xbox’s.
It’s really strange the button works for factory settings, but not syncing.
Any ideas anyone.
Thank you in advance.
P.S.
I don’t think it matters, but it is a Forza limited edition, which is why I don’t want to send it to Microsoft to be replaced.
1 Comment
Thanks Steven.
I’ve tried that, no luck.
by
Add a comment
Chosen Solution
I figured out the problem. I’m such an idiot. I forgot to plug the wifi board back into the motherboard.
DOH!
That is why it wouldn’t sync even with the USB cable.
Add a comment
Have you tried doing a hard reset?
  1. Holding the power button down for 10 seconds while the system is on will perform a hard reset.
  2. The Xbox One Will Switch Off.
  3. Power on the Xbox One again. You'll see a green start-up screen.
  4. All your data is preserved, but the cache will be cleared and settings may reset.
That has worked in the past when I had this issue.
Add a comment
Add your answer
Craig Veale will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 209
