Model: Dell Vostro 1440/1450/1540/1550 Released Date: 2009
it is completely dead, only 19 volt comes
Sir, I have a dell vostro 1550 model laptop, it is completely dead, only 19 volt comes, no indicator is turned on, can there be a problem?
Add a comment
Chosen Solution
Is it posting, or doesn't it show anything?
It does sound like a voltage issues, I would up it to a higher level and see if it boots then.
Also check out other methods, firstly try with a new cable and see if it helps.
Score 1
Add a comment
Have you tried it with the battery disconnected and just the power supply/charger plugged in?
See manual:
vostro-1550servicemanual.pdf
page 11.
Does that fix it? Then just defective battery.
No?
Then try resetting the BIOS by taking out the coin-cell battery, page 33 in manual, and then press the power button to discharge any power in computer. Should be 3 volts. Replace if lower.
Let us know how it goes.
Score 1
Add a comment
Add your answer
Sameer Mulla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 139
