Can I play movies of my tv
Can i hook the projector directly to tv
Hi,
What is the make and model number of the TV?
Usually TV's do not have a video out option, only audio out.
You may wish to check the connections on the back (side?) of the TV though, just in case.
Also HDMI connection in TV’s is normally for video input and not video output.
What is the source of the video signal?
If it is a “box” of some description you may be able to connect the projector to it to view the video signals, depending if it has video output options that can connect to the projector’s video input options.
If it is a direct antenna then it can’t be done if the TV doesn’t have video out options.
If the signal source for the movies you wish to watch is a dvd player then you should be able to connect the projector to it
Depends on how picky the content is about having HDCP - you will never get things like Netflix or Blu-Ray movies to work (honestly, you’d probably want a better projector anyway!) but anything that isn’t tied to content protection will be “fair game” on a projector like this.
Keep in mind the image will not be the best since this is a toy projector like today’s LED ones with the 320x240-800x480 single LCD configuration (50-150 actual average lumens), so set your expectations accordingly.
About playing movies from your TV onto a projector, it really depends on the make and model of your TV. As mentioned, most TVs don't have a video output option, so it might not be possible directly. However, if you're looking to watch movies, there are plenty of options out there. Have you considered checking out the movies playing in theaters right now? There's something special about seeing movies put right now up on the big screen, don't you think? But if you're set on using your projector, maybe consider other sources like a DVD player or streaming device. They usually have video output options that can connect to your projector.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 255
