Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Why isn't my new battery charging?
I have installed the new battery that was recently purchased and am now having an issue with it charging and sometimes the battery indicator doesn’t display. Please advise.
Update (03/26/2020)
Screenshot of current battery activity.
Screenshot of original battery activity.
Score 1
3 Comments
@tezarelli…what made you replace the battery in the first place? typically, after a new battery and its not charging still, could be a problem with the charging ic or port itself. also could be incorrect installation so i would double check the connector first.
by
@tezarelli - Install this gem of an app CoconutBattery take a snapshot of the main window and post it here for us to see Adding images to an existing question
by
@danj Here is a screenshot of what it is currently showing. Thank you in advance.
by
Add a comment
1 Answer
Chosen Solution
Do you still have your original battery? If you do lets slide this battery out and use your original battery to make sure its the battery.
CoconutBattery is not showing the any data so that implies the battery is not sending the data to the SMC logic so the system can offer it to the OS and any app’s like CoconutBattery.
If your original battery shows values then that proves the replacement is bad. Otherwise the pathway between the MagSafe charger to the SMC logic on the main logic board will need to be checked.
Score 1
2 Comments:
My apologies for the delayed response - it has been an extremely busy week. I have reinstalled the original battery as you suggested and provided the necessary screenshot above. Thank you in advance.
by
You got a bad replacement battery, return it with printouts of your two CoconutBattery outputs to prove it.
by
Add a comment
Add your answer
Taquonton C Johnson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 98
