Smartwatch from Samsung released in August 2018.
59 Questions View all
Gets extremely hot on charger and battery went from 100% to dead in li
So my husband's watch gets extremely hot when on the charger and goes from 100% to dead in a little over an hr! What can it be? Does it just need a new battery? The watch was fine a few days ago
Add a comment
1 Answer
Most Helpful Answer
For me, the cause was moisture that got into the heart rate sensor after the adhesive holding the glass over it failed. I thought I was safe because I had replaced the glass and adhesive fairly quickly and I keep my watch dry, but I started experiencing issues a week or two later like you describe. Evidently some moisture got in there and caused some corrosion.
I took the back off the watch and disconnected the heart rate sensor and everything is back to normal (minus the nonfunctioning heart rate sensor). To disconnect the heart rate sensor, you only need to remove the back and detach the ribbon cable going to watch back. You will also need to place something in between the connector and where it attaches to the pcb, as it can and will reconnect itself when you reattach the back to the watch. I just used a piece of tape between the connectors to make sure.
Score 1
1 Comment:
Omg, mine also has the same problem. When i connect the HR Sensor connector, the back glass become so hot, and the battery drains quickly. Mine also has the charging problem. It won't charge and keep getting hot. Maybe because it's drained faster than the charging. But I'll try your method first. Thank you!
by
Add a comment
Add your answer
powerhouse1882 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 203
