Replacing the motherboard ribbon cables ¿Are the cables the same?
Hi!
I’m trying to replace the two ribbon cables between the motherboard and the keyboard of my laptop.
Now don’t turn on.
I have doubts about the replacemant cables that I have got. There are diferences from de originals (see attached images). Aditional number E319831 not appear on the new one, green words vs blue words and the alloy seems diferent.
Do you know if the cables that I buy are correct?
Thank you very much.
Add a comment
1 Answer
it should work if the pin count and lengths are the same. go for it
1 Comment:
Thank you for the answer!
I'm worried about the alloy... I tested with a multimeter and I can see that the voltage read with the old cable is pretty higher than with the new one. Thanks!
by
Add a comment
Add your answer
Jordi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 181
