My aux headset makes scratchy noises and echos?
A few days ago, i plugged in my aux to my gaming headset (nothing special about it maybe like a 40$ headset) and i noticed that the audio was all messed up. What was happening was the environmental sounds (footsteps, gunfire, looting) was a kind of spacy sound with an echo. But there was an obvious difference when somebody talked in the video, the voice was warped and messed up and i could slightly understand what they were saying but not very well. Then i looked up some solutions and they told me to troubleshoot the hardware and it ended up reinstalling some type of hardware and when my computer rebooted the audio was TWICE as bad if not worse. Now i can barely hear voices and they are extremely warped and quiet and in game sounds are worse than before. Any ideas what i should do? I feel its necessary to also state that the headset works perfectly when i connect it to my ps4 controller and it sounds clean.
2 Comments
Hi,
What is the model number of the laptop?
What is the audio like coming from the laptop's speakers?
by
Hi,
The product number is "Inspiron 5570".
The audio coming from the laptop's speakers sounds perfectly fine, nothing wrong with them.
by
Add a comment
1 Answer
Most Helpful Answer
Try using DeoxIT on the jack… there are all kind of applicators, and a wipe should work well for your use. Alternatively, you can spray it on to a lint free cloth as well. Just apply it to the jack, plug it in and unplug it a couple times - it will migrate and address any corrosion in the socket as well. If the noise you are getting is from a dirty connector, it should clear it right up. Good luck.
Score 1
Add a comment
Add your answer
pjcrowley kek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 40
