Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
My iPad pro 2017 10.5 bent
Update
Sorry it took me so long to post, these are the pictures of how it is now, I’ve already tried to bend it back but I’m to scare of making it worse
Hi, I have an iPad pro 10.5 2017 that I recently bought, the problem is that I dropped it from my bed and now it is bent on the top right corner, the display has a thin “hairline” inside the screen that is barely visible but that’s another problem.
The side of the screen with the bent does not stick anymore to the frame(you can see the backlight from the side), is there anything that I can do about that without buying the back case for the ipad?.
Score 1
1 Comment:
Sorry it took me so long to post, these are the pictures of how it is now, I’ve already tried to bend it back but I’m to scare of making it worse[image|2111785][image|2111786]
by
Add a comment
If you’re willing to tear it down, you might be able to bend it back into place. Unfortunately their choice in thin aluminum does bend quite easily, especially in the 2018 and newer models. I would get a protective case for yours as well.
2 Comments:
Can it be done without touching the battery?
by
Post some pictures so I can get a better look at it please. You should be fine but I wanna make sure that's all
by
Add a comment
I think yes you should try to bend it back but just a heads up that I have the same iPad and this happened to me and it was hard to bend back. You will need to have very strong hands
Add a comment
Add your answer
fede will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 14
All Time: 941
