Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5 Questions View all
touch pad replacement Asus n53
My top cover broke and I got a replacement for it but comes with no touchpad. is it possible to remove the touchpad from the original cover and install on the new cover? if so how can I do it?
Score 1
2 Comments:
Can you add pictures of the new cover and the old one, it would help to know more exactly what part is missing on the new one and needs to be moved.
Adding images to an existing question
by
Apologies. Unfortunately I've already fixed the device therefore I won't be able to take any pictures.
The touchpad board is actually glued to the cover I had to heat up the touchpad area on the cover (not the board) and used a metal pry tool from my IFIXIT to remove it.
Bit by bit the glue was coming off.
I was able to just stick it to the new cover and is working well
by
Add a comment
1 Answer
Hi @xinwarrior
Based on some research into the ASUS N53 it looks like this touchpad is easily transferred after removing a few surrounding screws.
Add a comment
Add your answer
Joao Araujo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 344
