Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
875 Questions View all
How to fix my sound?
I have an iPhone 8 which I got around Christmas time and today out of the blue, my sound doesn’t work, I tried every method restarting it absolutely everything and nothing works, I plugged in earphones, no sound either, I had contacted Apple and they said a battery replacement might help it but I thought that just sounded silly? When I even press the volume up and down buttons the slider doesn’t appear showing the volume going up. any help would be appreciated
Score 1
2 Comments
nope never, and yeah apple are pretty bad for help
by
tried everything so far, done a whole erase of my phone last night, nothing is different so have it sent to a close friend to have a look at it and see if they can see anything wrong with it
by
Add a comment
Most Helpful Answer
Lol @apple battery advice
After performing all suggestions above if you still don’t have a favorable result, try placing a call while on the call check to see if the loudspeaker button greyed out. If it is you may have a board issue (audio ic chip)
Score 1
1 Comment:
just factory reset it, sound still doesn’t work, vibrate, nothing, really think it’s something wrong with the speaker at this point but thanks for all the help
by
Add a comment
Glad you decided to seek help elsewhere rather than take Apple’s advice. They have a tendency to bend the truth. Anyways has your phone ever been dropped in water?
Add a comment
Are you on the latest software? If not then update. Make sure your phone isn’t on vibrate. Try asking Siri to put the volume higher, if that works it means that you have an issue with your buttons on your phone.
1 Comment:
yeah updated it yesterday, buttons are fine. can’t even change sound in the control centre, vibration doesn’t work, earphones, nothing and it just happened out of the blue so i don’t know what is the reason
by
Add a comment
Add your answer
Sarah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 568
