Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
several problems with iPhone 7
Bad WiFi. Home button doesn't work. Input speaker does not work. People can't hear you when you call them. Voice memo does not work. Headphones do not work , charging port works fine to charge the phone, but headphones do not work when connected .
2 Comments
I get there's a lot of issues, but was the phone damaged or dropped in water?
by
Not sure, I bought the phone used
by
Add a comment
1 Answer
Chosen Solution
so you have an issue that is called audio ic it need to be taken to some one who can do micro soldering that will solve all the issues you have with all of your audio wifi can be replaced if it is damaged with the micro soldering expert also does touch id work but not home button ?
Score 1
Add a comment
Add your answer
mikespring1972 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 73
