iMac doesn't wake up after replacing HDD to SSD
Hi,
I’ve just replaced the HDD of my iMac (21.5” late 2013) with a SSD (and upgrade Memory up to 16GB).
I installed Mac OS Catalina. Everything was fine : the iMac started and run without any problem so I finished to seal the screen.
But, after a while, when I try to wake the iMac, it does not respond. Screen remains black (no backlight).
I have to force the reboot. Then I usually get everything back, but sometimes, even when I restart it, the screen remains black and I have to restart it 2,3 o4 times before it works properly.
I’ve read a lot of thing and my guess is that it comes from the ssd but I have no idea how to fix it…
Thanks for your help !
Update (04/18/2020)
After having switched back the ssd with the original HDD, I still have the problem... Could it be from the RAM ?
Or from some damages I could have made somewhere ?
Some pictures of the display connectors
4 Comments
Who's SSD did you install make & model
Did you follow the iFixit guide?
by DanJ
@danj
I installed a Crucial CT500MX500SSD1
I followed the iFxit guide to do the upgrade.
But even after having put back the original HDD, the problem persists...
Thanks !
by JMPPFR
I was wondering if it could be from the power supply.
On step #36 of this iFisxit guide, I had some trouble to unplug the cable (but I eventually succeed).
iMac Intel 21.5" EMC 2638 RAM Replacement
by JMPPFR
Generally I recommend doing one task at a time and then checking things to make sure it’s working before doing the next. I would have done the HDD to SSD upgrade first, then prepped it up before tackling the bigger job of upgrading the RAM. That way you know what you need to focus on if something goes wrong (in either case)
by DanJ
