Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 Questions View all
Is this possible to do? Planning on turning iMac into monitor
I’m planning on turning this 2006 24 inch iMac into a monitor for another computer and I’ve bought the LVDS controller board and it needs 12V power so I bought an adaptor to use the original iMac power supply by connecting the SATA power cable to a DC In Cable to power the controller board but i found out the inverter which is part of the display needs 24V of power separately and i don’t know how to give it power? So I was planning on possibly using the original motherboard of the iMac and connecting it to the inverter which is how it was powered in the original computer through a cable. Could I do that? Use the controller board to control the LVDS signal but have the original iMac motherboard power the backlights through the same cable it did originally in the computer? I would have to press the power button and all so the computer thinks it’s on and powers the sata power and inverter
Add a comment
Most Helpful Answer
This system uses CCFL lamps for the backlight unlike newer ones which use LED.
There is a inverter which requires the 24 volts and then bumps it up from 200 volts to more than 600 volts at a high frequency. The lamps are no longer available so if the display is dim there is nothing you can do to fix it.
You may want to look for a newer system to convert.
Score 1
Add a comment
Here’s a pictorial guide on how I did it:
How to build a display using a iMac
Score 1
1 Comment:
@mayer - Missing a lot of that wisdom you have ;-}
Can't wait to see this finished.
You also have some other stuff mixed in at the end, it looks like both MacBook Pro TB and MacBook display disassembly.
by
Add a comment
Add your answer
Teddy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 135
