AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
65 Questions View all
Repair or replace MagSafe to MagSafe 2 Converter?
My MagSafe to MagSafe 2 Converter has become loose. One side of the laptop side is lose and when pulled out it will not conduct electricity to the laptop. Pushing it back in fixes it.
Try some superglue? Try to purchase a replacement?
Add a comment
1 Answer
It just fits into the outer sleeve. Some super glue should work fine, just don’t get it on the contacting surfaces.
If you can I’d actually try to pull it our a bit more, apply the super glue the push it back into place. Maybe softly use some vice grips to hold it in place till it sets up.
Add a comment
Add your answer
James Harrison will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 147
