The Yoga 520-14IKB is a 14" laptop released by Lenovo in 017. It can fold 360 degrees and has a touchscreen.
4 Questions View all
Why is my laptop alternating between a grey screen and normal display?
Hi, I am facing the same problem with a Lonovo Yoga 520 after dropped it. Some times I can have a normal screen for a few hours and turn back to grey.
With the COVID-19 I am not able to bring to fix how can I do myself?
Thanks
Add a comment
1 Answer
Hi,
Could you please verify the full model number of the laptop?
What OS is installed in the laptop?
Does this occur all the time regardless of what you’re doing on the laptop or just when watching online videos or playing games?
Try connecting an external monitor to the laptop's HDMI port and check if the problem occurs on it as well. Even a TV can be used as an external monitor as long as you have the appropriate cable to connect the two together. Don't forget to press the F10 key to toggle the display between the laptop only, external only or both on together.
Also if the problem occurs often enough try starting the laptop in safe mode and check if it occurs then. Search online for (insert OS) safe mode to find out how to do this for your OS, e.g. Win 7 safe mode or Win 10 safe mode etc.
Add a comment
Add your answer
Dany Bb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 363
