Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
217 Questions View all
MacBook is super slow, kernel_task above 700% cpu, PMF006 and PPN001
My MacBook Pro (2018 15” Touch Bar) started being super slow suddenly and fans are running at max speed even on a cold start. I quit all running programs and checked the activity monitor, there is a kernel_task using between 700-1000% cpu. I shut down the computer and ran Apple Diagnostics, it gave me the following errors:
''There may be an issue with the System Management Controller (SMC). Reference Code: PFM006''
''There may be an issue with the power management system. Reference Code: PPN001''
I tried resetting SMC but no luck.
I read on this website that some people had that issue after a liquid damage, that reminded me I had a few drops of a liquid on the trackpad last week (literally a few drops).
So I decided to open the computer (first time it is opened, I had never touched anything inside) to look for any liquid damage on the computer. I followed a tutorial on this website to remove the trackpad, and I didn’t find any corrosion on the trackpad nor on the cable between the trackpad and the board. I checked the mother board for any corrosion too but I didn’t find anything either (I really doubt the liquid would have gone to the motherboard anyway, since it was literally a few drops on the bottom left side of the trackpad. Also, I haven’t unscrew the mother board and check on the other side for any liquid damage yet.
So here I am. The computer turns on and load etc, it’s just super slow, fans are running at max speed and the kernel_task is always above 700% cpu…
Has anyone had this issue? Do you think I should unscrew the mother board and check under it even though I doubt the water would have gone so far? Should I replace the trackpad even if it seems to work properly? Are there other sensors I should check? (I believe this issue is due to some sensor not working properly)
Here is a screenshot of TG Pro:
Here is a screenshot of Macs Fan Control:
Here is a screenshot of iStats from the terminal:
I see some sensors with weird values with iStats but I’m not sure if they are really relevant since it shows negative values for cpu core 7 and 8 but I only have a 6-core cpu… Plus, TG Pro and Macs Fan Control seem to show normal temperatures.
Thank you for your help!
Score 1
2 Comments
Running slow with loud fans points to a sensors issue. Can you post all the sensors with abnormal values? ( this MacBook probably needs a microsoldering repair)
by
@mronion64 I already posted all temperature sensors I found, are there more than that?
Also I went to an Apple certified center. They ran a diagnostic test and told me a sensor (soldered to the logic board) is failing, so I have to replace the logic board. They said it's gonna cost around $1000, so I'm not sure what I will do at this point.
by
Add a comment
Chosen Solution
I went to an Apple certified store, they ran a diagnostic on the mac and they told me something is wrong with the logic board, and that I have to change it. They told me it's gonna cost around $1000. I didn't do it.
I removed the logic board and checked both sides, there wasn't any visible water damage, and since I spilled a few drops of a liquid on the trackpad only, I thought it might worth trying to replace the trackpad first.
So I changed the trackpad, and now everything is working perfectly!!! I ran the Apple diagnostic and I don't have errors anymore!!! I just saved $1000!
Apparently there are two temperature sensors inside the trackpad, and they didn't work normally on mine (probably due to the water damage).
See this screenshot, there is now two more temperature sensors visible with TG PRO, "Trackpad" and "Trackpad Actuator":
So if you have error codes "PFM006" and "PPN001" after a water accident on the trackpad, and if your logic board looks fine, try replacing the trackpad, even if Apple professionals tell you to replace the logic board. My next shot would have been to replace the trackpad’s cable but I didn't do it since that wasn’t the issue for me.
Also, I'd like to mention that apple diagnostic error codes were related to SMC (PFM006) and Power Management System (PPN001), TG Pro temperature errors were related to GPU and Power Supply. None of them were correct since the issue was 100% the trackpad.
I hope this post will help other people in the future!
Score 6
3 Comments:
Really glad you could fix it :)
by
@mronion64 Me too! Thank you :)
by
After reading this, I decided to clean the trackpad ribbon cable and it solved the issue. Thank you so much for sharing. :)
by
Add a comment
This definitely seems like a sensors issue. It wouldn’t hurt to try removing your motherboard and checking for water damage, but I doubt that it will be enough to fix it. You don’t have to replace the logic board; there are many reputable microsolderers out there. Louis Rossmann has a video about this exact issue, so he could definitely help. Also, iPad Rehab has some very smart people, but I don’t know if they work on macs.
3 Comments:
Best of luck Alex!
by
I completely removed the motherboard, and I didn't find any water damage on either side.
Thanks for your help @mronion64
by
No problem :)
by
Add a comment
Alex!,
(And all the other people finding this thread like me);
Thank you for your OP. I had a similar issue on a 2016 15-inch MPB, I have some additions that might help other people out.
So first of all, I had a lot more errors to begin with, I bought the MBP as "broken, keyboard doesn't work". And I like a challenge.
Previous owner attempted to replace the keyboard, but failed miserably. The right speaker connector was torn from the board, all the pentalobe screws were damaged by a torx driver, and most of the torx screws were damaged due to over tightning. But that only makes the job harder, doesn't throw any errors.
Since all the moisture indicators were still white and there was absolutely no corrosion on the board, I didn't suspect liquid damage at first (maybe the butterfly keyboard issues prompted the previous owner to replace the keyboard?)
I had the following errors:
  • PPT001 (because I disconnected the battery)
  • PFM006 (like you in OP)
  • PPF004 (fan error, since the keyboard was dead)
  • PPF003 (fan error, since the keyboard was dead)
  • PPN001 (like you in OP)
PPF003 and PPF004 were fixed by replacing the keyboard + keyboard flex. But after reconnecting the battery I still had PFM006 and PPN001. As a result the CPU and GPU were all in "safe state" (locked in low power state) and thus performance was terrible.
Having found this thread I did some more research, and I found things similar to you, with some exceptions;
  • TGPro found two "case" sensors, but they were persistent upon disconnecting the Touchpad (though the keyboard stopped working without touchpad?)
  • iStats Menus was actually showing missing (identified) "Palm Rest" temperature sensors!
I thought this was interesting, since most apps just hide sensors that show faulty or no information like TGpro (and I couldn't get iStats console working for the life of me).
Of course, like yours, my MBP is working great with a new touchpad! (and whilst removing the touchpad, brown sticky goo appeared! used-to-be coke or coffee?)
After that the palm rest sensors show up in basically all monitoring apps.
Add a comment
Add your answer
Alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 40
All Time: 5,899
