A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
74 Questions View all
Having problems upgrading i3 with i7 CPU
Hi,
I have a 2019 21.5” iMac i3 3.6 GHz I3-8100 with 8GB
I first upgraded the HDD to SDD which works perfectly
Next I upgraded the RAM from 8GB to 32GB and it too works perfectly.
Finally I bought a new CPU [Intel Core i7-8700 3.2 GHz] but it didn’t work.
I’ve already tried re-installing my old CPU [Intel Core i3-8100 3.6 Ghz] and that works just fine again.
What was the problem? And which CPU do I have to buy to upgrade my iMac.
Thank you for your attention.
Score 1
Add a comment
1 Answer
Hi! I have the same issue. When I tried to upgrade the CPU from the same i3 8100 to the same i7 8700 the system won’t turn on. When I came back to the original i3 8100 everything was fine.
Is it possible to upgrade the base model’s CPU to anything?
I read something about micro-code in the iMac’s bios, but the same iMac has the configuration with the same i7 8700 cpu. It must be compatible!
Where’s the catch ?
Add a comment
Add your answer
SERGIO GIRALDO will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 190
