Model A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac13,2
Screen stuck on Low Resolution
Hi.
Video card is GeForce GTX 660M (if needed).
Upgraded HD to SSD and decided to refresh Thermal Paste as computer is 8 years old and hasn’t been open (screen adhesive seems to be original). Now screen resolution is at 1280x720, everything is pixelate. Even Apple logo on startup. Going to System Preferences - Display shows Only resolution mentioned above. No Other Resolutions are listed.
Did I somehow damage Video card by reapplying Thermal Paste? I work in computer repair shop so have done it zillion times.
Thank you for taking a look.
Add a comment
Most Helpful Answer
Did you try running diagnostics?
Restart your system and press the D key to enter
Reference: Mac startup key combinations
Score 1
3 Comments:
Diagnostics won’t run, it won’t even start (held D key for solid 2 minutes). Just white screen. Recovery - loads, OS - loads and works, Diagnostic - won’t.
by
@onetailbeast - Try using a USB keyboard
by
Was using USB keyboard.
by
Add a comment
Had the same problem. Tried everything from reinstallation, resetting PRAM, SMC, etc. Been on call with Apple support for a half an hour. Unable to run diagnostic, not even remotely or from a flash disk. Nothing helped. Brought the iMac to an authorised service centre here in Brno, CZ and they quoted me €700 for a new LCD. Which is a basically price of the whole iMac…
Add a comment
Add your answer
onetailbeast will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 780
