The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Charger port replacement compatibility
So last year maybe around August I had got my laptop repaired by Apple and by November it’s was damaged in the same place. So I need to know what charger port replacement would be compatible with my MacBook model a1502?
Add a comment
1 Answer
Most Helpful Answer
I’m suspecting you have a more basic issue here. While you may need a new port connector as well the root issue is the bad/fake MagSafe charger that’s damaging your system. Here’s the best source for the replacement charger Apple 60W MagSafe 2 Power Adapter (MacBook Pro with 13-inch Retina display). Anything you find on Amazon or eBay is Fake!
I would inspect the systems MagSafe contacts often I find them blackened from the arching. Also inspect the while plastic for debris as well as the pins in the cord.
In this picture the top connector is dirty and needs to be cleaned.
Here’s the needed part 13” Retina MacBook Pro DC-in, Magsafe 2 board, Apple P/N 923-0560 and the guide MacBook Pro 13" Retina Display Early 2015 MagSafe DC-In Board Replacement to put it in.
Score 1
Add a comment
Add your answer
Rebecca will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,120
