Is G5 model A1076 the logicboard the same as the model A1058?
My G5 can't boot and the led 3 in logic board can't light,so I think maybe there has some problem with my logic board,and i have another working G5 model A1058 17 inch,i open it and found the logic board is the same,but i not sure,so my question is can i put the 17 inch the logic board replace the 20 inch logicboard,thanks helping me
1 Comment
Does it mean every mac the display the CPU and logic board is connect with each other?if i put mac mini the whole thing in imac g5?can I light the display?
by
Add a comment
Chosen Solution
The 20" A1076 uses a 820-1747 board whereas the A1058 uses a 820-1540 board. The boards are not identical. Compare the connectors i.e. J7600 etc which is not located where you would expect it etc. It is a different board. The Mac Mini uses a different technology altogether and it will not connect to your display etc.
Score 1
1 Comment:
thanks,now i clearly know
by
Add a comment
Most Helpful Answer
These logic boards are not interchangeable.
Score 2
1 Comment:
Chould u tell me why,and if i replaced,what bad things will happen?thanks a lot
by
Add a comment
Add your answer
Johson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 80
