The HP Envy TouchSmart 17 is part of HP's Envy series of high-end laptops. It takes a full HD touchscreen from HP's TouchSmart series.
2 Questions View all
How does one take the back cover off after all visible screws are remo
The back split along the left rear causing a 1/4 “ gap, and the left hinge is misaligned. How do I remove back after visible screws are removed. I’m planning to take spring out of left hinge and reassemble.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi,
Here’s the maintenance and service guide for the laptop.
Go to p.72 to view the necessary pre-requisite steps and then the procedure to remove the display hinges.
If you need to replace the hinges the part numbers are at the top of p.72. Search online using the appropriate to your model hinge part number only in the search term of your browser, to get results for suppliers of the part.
Score 2
1 Comment:
Very helpful. thanks
by
Add a comment
Add your answer
Alfred Kirkwood will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 5
Past 30 Days: 13
All Time: 372
