The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Questions View all
Part of screen not touch responsive after display replacement
Thank you for your guide. I’m almost finished but before closing the screen to the frame I’m testing whether the touch works. But on the unlock screen all numbers but 1, 2 and 3 work. What could cause this problem? I have installed the kapton tape on the replacement screen.
Score 2
Add a comment
Most Helpful Answer
Did you unhook the battery before you took off the screen and reinstalled it? Unhook the battery and disconnect the screen connector and get a magnifying glass and see if the pins were damaged. If they are ok on both connectors than take a qtip with a little alcohol and clean the connectors then brush them off with a soft brush. Reconnect and try it again
Score 2
Add a comment
Hey Allan Barr,
Thx for your comment, I also had small part of the touchscreen that did not responded.
Followed your steps and it’s working 100% now.
Thank you for your contribution!
Grtz
Add a comment
Add your answer
Michel Braamhaar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 584
