Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
Firmware Restore Problem iPhone XR
Hello. I am trying to restore the firmware on my iPhone XR. I start up the iphone it goes straight into restore mode. I try restoring the firmware from restore and dfu mode. It says preparing iphone for restore. After it says iphone is restarting it restarts and goes straight into recovery mode again. I’m thinking it is a hardware issue. I may be wrong. If it is a hardware problem what part do i need to repair. The front and back screen is cracked. I don’t know if that affects the restore process. If anyone can help me that would be great.
Add a comment
Did it get wet? If the back or screen is cracked liquid can come in. I would open it up and check if it has liquid damage and go from there.
Update (05/14/2020)
It sounds like you need to send it to a repair shop. I would recommend jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com you should check out there YouTube channels. But they can figure it out. Hope I
1 Comment:
I am not sure. If i open it up what do I check for if there is water damage? Also I heard that it could be a faulty part in the iPhone. What part or parts could cause that?
Thanks
by
Add a comment
Try to disconnect the front cam flex cable, rear cam flex cable and lcd flex cable you only connect battery and dock connector flex to mother bord and then connect the iphone with itunes. If it boots up you can conect flex cable one by one to check which part give the error when connected to motherbord.
Add a comment
Add your answer
Kevin Greaves will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 244
