The back of the phone is cracked. Can it be fixed?
The back of the watch has spider cracks all over it. Is there a way fix it?
To replace the back glass of the Samsung Gear S2
You can buy the entire back cover for about $20 or $13 for the glass. Make sure you get the adhesive with it so it can retain its water resistance.
Hope this helps you.
P.S. After I answered this I noticed the title said “phone”, but you have an image of a Samsung Gear S2 watch and the body of your questions mentions watch. The answer is for the watch. If you need help fixing the rear glass of a phone please list what phone that would be. Thanks.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 155
2 Comments
Where can I buy the back cover or glass?
by Chuck Goodwin
You can do a search for Samsung Gear S2 Rear Glass on Amazon or eBay. When I did a similar search, these are some of the results I got before. Naturally I suggest you do your own search and due diligence for that your buying the right part from a reputable vendor. I'm not endorsing these particular vendors in any way, but it's just an example to help you on your way on what the search results might look like. None of these replacement parts are genuine Samsung parts as far as I could tell, but that's usually the case when you are looking to fix electronics. No different then when you buy a new alternator for your car, it's usually aftermarket, the same applies here. Best wishes.
https://www.amazon.com/Ubrokeifixit-Comp...
or try here:
https://ebay.us/BHXC8H or: https://ebay.us/o3GS7q
and this listing gives you the whole back cover with the glass: https://ebay.us/qeqaEA
by Eddie de la Rosa
