All screwdrivers manufactured by iFixit and sold on iFixit.com
22 Questions View all
Why magnetizing is present only on one side of flexible holder?
Why in “iFixit 64 Bit Driver Kit” magnetizing is present only on one side of flexible holder? It is missing on side on which you attach selected bit, which makes them fall out when moved to more horizontal position.
Update (05/18/2020)
Below is image to show what I am exactly referring to:
Add a comment
Chosen Solution
This is what I am talking about. The head is aluminum. There is no magnetism on that side. If you need to, use an aftermarket bit magnetizer.
Score 1
Add a comment
Most Helpful Answer
If you are referring to the drive extension on the Pro Tech Toolkit, or the Mahi Driver kit, the end of the extension is aluminum (not magnetic). Push the bit into the extension all the way to hold it in place. If you need magnetism on the extension, use an aftermarket bit magnetizer, as pictured below.
Score 1
Add a comment
Add your answer
Tomasz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 302
