The Motorola Moto Z Play (model number XT1635-02, XT1635-01 and XT1635-02) is a droid smartphone that was released in September 2016. The Moto Z Play can be easily distinguished by the word “moto” placed at the top and the square home button placed at the bottom of the front of the phone.
58 Questions View all
How to remove stripped screws?
Hello, I am trying to replace a battery on the moto z play phone. I got the back off and screen separated. But can not get the little screw out to remove the metal piece holding the battery cord in place. Anyone have a suggestion on removing stripped screws? I have tried the rubberband trick but no luck.
Add a comment
Most Helpful Answer
Have you tried other screwdriver bits of different sizes and shapes? If that does not work you can carefully drill into the screw till the head comes off with a very tiny drill bit (see pin vise from here or amazon). Of course with this method you will have to replace the screw.
Score 1
Add a comment
That was not pretty. I ended up drilling the screws and doing my best to break off the top….which was challenging. I tried the rubberband trick and I think they were to far gone. The super glue did not hold and would just pop off. And then I even tried soldering the screw……nothing.
Anyway, I got the screw heads off and was able to move on.
Thank you for your responses and help. I greatly appreciate it. I am new to this….so lots of trial and error.
Score 1
Add a comment
Hi Melissa,
A couple of options with stripped screws, drilling is an option as Josh mentioned, but first, to drop a little super glue into the screw, then pop the driver in, wait a few mins then twist out.
Add a comment
Add your answer
Melissa Odom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 340
