Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 Questions View all
Surface only works when plugged in after battery replacement?
I did a full housing, screen, battery replacement for a Surface Pro 5
It turns on only when plugged in tried 2 batteries now still the same issue.
I tried force restarting it and doing a driver update still not working
My next thing to try would be desoldering circuit board off OEM battery and soldering it to After-market not sure if the risk of lighting the battery on fire is worth it.
Any Ideas?
Add a comment
1 Answer
Factory Reset the device with new battery fixed the issue!
2 Comments:
Hey Mark,
A bit of a digress but - could you provide any help on replacing the battery for the surface pro 5 ? Have looked online but can’t find a resource. I am considering following the surface pro 4 tutorial on this website, but I’d like to hear how you have tackled it first.
thanks
by
My boss and I think you may have to remove the daughter board off the old battery to the new it must be programmed to the motherboard. We gave up on the repair requires soldering near the battery. It could as well just be a bad motherboard not sure.
by
Add a comment
Add your answer
Mark D Schlossman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 592
