Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
Did screen repair and now it restarts every 5-10 mins
So I had done a screen repair on a iPad 10.5 inch didn’t check before to see if it was doing this but now it is and I don’t have the other screen because it was broken. It shuts off at random any advice possibly I have done everything from DFU to updating. It wont shutdown until ios is actually booted up other it can make it through the update cycle without running into anything. I only use plastic tools could’ve this been my fault or do you think its the screen or prior damage from when the kid fell with the ipad.
Score 1
1 Comment
Can I ask, did you solve this problem in the end?
by
Add a comment
1 Answer
Most Helpful Answer
It seems to me that the problem is no longer valid, but just in case and also for #humanemagician5 a few hints.
Check the log first. You can find it in settings -->> privacy -->> analytics -->> analytics data. There should be information about why the restarts occur (named panic.full file).
fingers crossing,
Score 1
Add a comment
Add your answer
humanemagician5 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 77
