2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Replacing Hard Drive with SSD
I want to replace the drive with the 1TB SSD from this site. The page for the SSD says it requires a SATA III controller. How do I confirm if I already have that? Or is that something I can install? Thanks!
Add a comment
1 Answer
That MacBook already has a SATA 3 controller, that is embedded with the logic board on a chip called the PCH (Platform Controller Hub or you could say chipset).
I assume you are referring to this SATA SSD right? If yes you can install that and reinstall MacOS (additionally do a time machine backup to do transfer) and you’re all set.
OWC Aura Pro 6G SSD
MacBook Pro 15" Retina Display Mid 2012 SSD Replacement
Replace or upgrade the SSD in a 13" or 15" MacBook Pro with Retina Display from 2012 or Early 2013. Image
Product
OWC Aura Pro 6G SSD
$49.99
1 Comment:
Yes! Thanks!
by
Add a comment
Add your answer
Josh Rushing will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 72
