2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Questions View all
The left hinge of my MacBook is suddenly very stiff
Hello everyone!
A couple of days ago, the left hinge of my MacBook Pro started to be very stiff. If I try to close my screen, it pops back open. I first thought that there was something stuck in the hinge, but I didn’t see anything. I tried wiggling the screen a bit, but it only made it worse. I am also a bit worried that if I open the case, the hinge will be broken and instead of being stiff, it will be very loose.
I tried searching the web, but I can only find MacBooks with loose hinges instead of (1) really stiff hinge.
Has anyone seen this problem before? I hope someone can help!
Score 2
Add a comment
1 Answer
Chosen Solution
Yes, we have seen this a few times!
Follow this guide MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
Get some WD40 spray it into the cap to concentrate the spray into a puddle (it doesn’t take much!). Use a Cotton Swab (Q-Tip) to dip it into the cap and then wipe the gap between the hinge.
Score 3
5 Comments:
Thank you very much for your help!
So I just need to remove the bottom plate and I can access the hinge?
by
Yes, let's first try the simple fix before we dig deeper. Don't soak it! It needs less than a drop.
by
Thanks!
I have exams for school this week (at home), so I'll try it next week. I don't want to do damage when I still need my computer.
I'll get back with my result!
by
It worked! Thank you very much!!
by
Oh my god! It works! Thank you so so much!!! Apple was trying to charge me a whole display assembly replacement 💀
by
Add a comment
Add your answer
Bernard D will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 2,842
