The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
142 Questions View all
No power, MagSafe port smells burnt
I have a MacBook Air which failed to turn on, connected the charger and got a Green then Amber MagSafe light,
Connected my neighbors charger and still no power,
I attempted an SMC reset which made the charger go from amber to Green for a moment then back to Amber
After later removing the charger I smelled a plastic burning smell from the MagSafe port on the laptop.
If anyone knows how to fix it I would greatly appreciate it
Add a comment
1 Answer
Most Helpful Answer
Lets give this a try, follow this guide to Step 3 MacBook Air 11" Early 2015 Battery Replacement. Now with nothing connected press the power button for a good 15 secs. Sit the system on its side so the MagSafe is on the top side carefully plug in the MagSafe charger, Did the system spontaneously boot up? If it did then you have a bad battery and will need to replace it.
Score 1
2 Comments:
Unfortunately I don’t have the screwdriver to remove the back but thank you for the advice
by
Here's the needed screw drivers:
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
T5 Torx Screwdriver
And you needed this tool too!
Spudger
by
Add a comment
Add your answer
will bevan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 208
