Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Questions View all
I replaced the screen on iPad 2 and I received a Black screen!
I replaced the screen in iPad 2,3.
After that I received a black screen.
The screen is completely black as when is off.
when I turn it I have the same screen. I don’t have illuminated light. Black complete as when is off!
i checked the LCD is working with another iPad so it’s not the LCD. Also I opened the motherboard and I saw that
I there is a blown fuse. Please took a look the picture.
Can we say that this fuse was blown??? Could somebody confirm it?
could be if I replace it will began to work????
Any suggestions will be highly appreciated!
thank you
Vinnie Venkov
Add a comment
1 Answer
No picture. Did you disconnect the battery before you unhooked the lcd and digitizer? It sounds like you shorted the backlight circuit.
1 Comment:
Thank you Allan. Also I"m sorry for the picture, now You can see it. I had a problem to upload the picture thats why wasn't there. So do you thing this could be a problem on the picture. Also pls give advise if You know where I can buy all those small parts fuse, transistors etc, if You know. Thank You so much for Your help!!!
by
Add a comment
Add your answer
Vinnie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 59
