Android's 4.4 OS with a 1600 x 2560 pixel resolution.
45 Questions View all
rear cover cable cut
Hi ….. my sister has Samsung Tab s 8.4 (SM-T705) …. and when she was trying to unpack the rear cover of the phone she cut some cable glued between the device and cover, I didn’t what this cable for.
the cable labeled by KL_LTE_MAIN_Rev.09 L
so I need to know the cable is it important or not …. what should I do if it’s important
Add a comment
1 Answer
Chosen Solution
I don't see a cable. It looks like it has contacts that “make contact “ when the case is closed. Probably to let it know that the back cover is closed. From what I see there is no cable and it should be
Update (06/02/2020)
There is no cable. It has contact points on each side that makes a connection when the case is closed. Nothing is missing. No cable is damaged. It's
Score 1
1 Comment:
you can see in the last photo something labeled with KL_LTE_MAIN_Rev.09 L, I don't if it is cable or not, but what I know it cut off
I think it's something related to the LTE antenna?
by
Add a comment
Add your answer
AHMED OM will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 74
